Lubricant question, try and figure this oun out.. >
The old O ring bushings on my calipers are totally shot, they are sqished, cracked, and just plain wore out.
Getting new ones today, I don't want this to happen again, I think it's a big source of the hard pulling to the right when I brake.
What kind of lubricant should I use on the bushings to prevent this, I'd assume axle grease would eat away at the rubber, lithium grease doesn't seem like it'd be thick enough to stay on there.
Shane McConnell
macgyver@thirdgen.org [*]Owner of a 1991 Camaro RS, 305 5-speed.[*]Owner of a 1979 Camaro Z28, 350/350.
(Reminder to self, change oil at 100,000 miles.)
Shane McConnell
Car: 1986 Firebird
Engine: 2.8 V6
Yep, silicone.. Pep Boys is selling little packets (like a Ketchup packet) of silicone brake part lube for $0.95. Previously, I was using a Silicone Dielectric SL-4 (forget the manufacturer, it's not Permatex) for the caliper stuff. I'm not sure if the dielectric is the same stuff, but hey, they're both made outta silicone!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Try Permatex Ultra Disc Brake Caliper Lube, p/n 24110, which is a green synthetic grease.
Pretty expensive, ~$11 for a pint, relatively a new product so you may have to go to a major brands auto parts store.
I have no long term results since it is new.
My auto parts guy says all the professional garages are now using this. My guess, probably a step up from silicon grease.
Regards, FJK
Regards, FJK
db057
08-11-2015 10:11 PM
