ZF 6 Speed Question
Car: 89 Iroc Z Cnvertible
Engine: 409 SR
Transmission: 6 speed
ZF 6 Speed Question
I have looked high and low for this, does anyone know what the torque rating is for the ZF 6 speed?
Thanks.
Thanks.
Car: Take
Engine: Your
Transmission: Pick
It is freakin huge. They are used behind the 8.1L and the Duramax Diesels. I will look when I go to work next time for you.
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
About Me
Savannah, GA
'97 Bonneville SSE
About Me
The 89-93 Zf's addy claim 450lb TQ and the 94 up dropped to 400 due to the different gear cut pattern. The changed the patternt to help quite down the idle noise. The Zf came with the dualmass flywheel. The is basically a two piece flywheel. runnig a ZF with a typical single mass flywheel produces in some cases a disturbing idle noise. (like looses screw in a beer can.) this dosnt hurt anything .Hope this helps
Dennis
85 vette,383,miniram,ZF6,4.10's..best ET 11.92@118.00 60' 1.68
http://geocities.com/bowtie8
Dennis
It is highly underrated! We have used many of them behind twin-turbo small blocks and nitroused big blocks with no problems. Lingenfelter installed one in a 1st gen car with a 632" big block. Zoinks!!
1989 Formula 350, 10.5:1 383", TFS heads, Comp Cams blower grind, TPIS Mini-Ram, BBK 58mm throttle body, Vortech S-trim 15 psi, DFI, 42# injectors, S/X fuel system, MSD ignition, SLP 1.75" headers, Flowmaster exhaust, MW Racehouse 700R4, Currie 9" w/3.50 gears, Jeg's sfc's, Jeg's lca's, S&W 8-point rollbar, lookin' stock street racer...
Best ET: 10.796 @ 125.8 on 16" Sportsmans...
Engine: 409 SR
Well that's what I kind of figured but wasn't sure. I have heard that the ZF 6 was about the same rating as the T56, and I have heard from other sources that it does indeed hold up beyond the 500 ft/lbs torque mark. What I'm getting at is that I would like to find a manual 6 speed that will hold up to at least 500 ft/lbs of torque without question.
I have also heard rumors (haven't confirmed it yet...) that if the ZF ever has any mechanical problems it would have to be sent to Germany for repairs. Where the T56 obviously could be fixed at any reputable tranny shop.
Any one know of anyone who has put a ZF 6 in a 3rd Gen?
Thanks for the help...
92 Camaro RS
89 Iroc-Z Convertible
92 Camaro RS
