Will teflon tape stand up to atf?
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
i have a slight tranny leak around my lower trans line on my th350.. it is tight but it appears that it leaks around the threads.. could i just slap some teflon tape on it or will the atf eat it? is so would some atf rtv work if i put it on the threads and give it a while to set up?
It may...that's a tapered/flared fitting, should be no need for Teflon tape...probably the fitting in the tank or on the line has damge and should be replaced.
roysatikas
09-22-2015 08:15 PM
700r4, atf, compatable, compatible, eat, fittings, leak, leaking, lines, ptfe, tape, teflon, tefolan, th350, transmission
