Some more probs after cam swap.
For those who dont know, i swapped an L98 cam out of a vette into my L03.
The car is running Better. BUT...
1. Hard to keep running after startup. Sounds like either i swapped in a 280 580/580 or the timing is way retarded ( but its not, the timing is fine) and its smokes like hell. once I give it some throttle it's fine..evens out and idles normally. I have no Idea what to do w/this.
2. in first gear I have nothing undr 2800-3000. Barely breaks the tires loose. From there on it pulls great, through all gears.
My guess is that it's the crapola 273's. I dont think they are playing well w/ the cam.
Ideas, thoughts, suggestions?
Thanks,
Rock
"Real Men Flush 5.0's"
My RS
Thanks,
Rock
My RS
1 Post
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Yeah my idle is kinda ****ty to. Sounds cool. But sometimes it feels like it's about to die. ANywayz nothing is wrong. I never died once. And as for the power things. That's probably just an effect of the cam. Cause that's the same as mine. It doesn't really have any hp lower than 2500. And yes it's also deffinelty about eh gears. Cause the cam just gave you high end and took away some low end. So the gears are killing you. Maybe you've seen my post on the NOn tech board. Where 3.27 w/posi. Changed my e/t from 16.2 to 15.6 I later hit 15.3@91.11 with my timing bump up.
Chris
91 RS 305 TBI
Team Neo Blood
Chris
91 RS 305 TBI
Team Neo Blood
see its posts like these (and a lack of talent) that keep me from getting serious with my car. Ive already got a cam, but I cant keep my car down for weeks while I sort out cam swap problems......plus no one seems to be able to tell me what springs will work with my cam. Ive also decided if I go ahead and swap the cam, I should change the heads to the 305 torquers too
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I do not think your car should be running like that. Sounds like a vacuum leak to me, they will do exactly that. If you had a TPI car I'd say perhaps a misadjusted TPS or IAC, but I frankly don't know what exactly the TBI has in the way of sensors, etc.
I'm running a bigger cam than that in my 86 305 TPI IROC (204/214 @.050, .420/.442). It does not have any kind of driveability problems. Now you might have lost some low end power, and I'm sure the 2.73s are hurting you, but my guess is that will pick up some from where it is now at least when you sort out what the heck is wrong w/ your idle setup.
You're going to need to talk to a TBI guru to get it sorted out, as I don't know enough about TBI, but it is definitely some kind of tuning problem, and is not normal.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Have you set your Idle air? I put a cam in my LO3 (check my sig) and that was one of the first things i did. Mine definately fells like it's gonna die but it rarely does. I've had it happen once or twice. Also check your MAP sensor connections. Pull your codes from your computer. After a cam swap you will have codes set. Definately make sure you don't have a vacuum leak, that can be a big problem. Try a few if the things we've listed then come back to us and we'll keep helping till it's fixed. Good luck man!
Later,
Lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
Later,
Lars
'92 RS 305 TBI
K&N Open Element
Performer Manifold
Car: Turbo Buick
Engine: 3.8 V6
Lars has a point, adjust your minimum idle. Infact, re adjust everything and play with your timing till it runs best. I have a feeling that the cold startup programming in the chip could be a little off.
Pablo
Pablo
Ive checked everywhere for vaccum leaks. Im going to adjust the Idle air again but nothing seems to help. I think the one thing that I did not point out is that when the car is cold (morning) it cranks fine. The rest of the day it cranks like crap.
My RS
My RS
