§ Drag Tire Sizing §
I don't know drag tire sizing, like MT's ET Drag Slicks. Suppose a tire is sized 28 x 11.5-15. I'm sure the 15 is the rim size it needs, but other than that, I can only guess. Can someone enlighten me as to what each number means? Thanks a bunch
--=¤ Soon to Come ¤=--
1985 Camaro IROC-Z
'88 Vette L98, performance rebuilt 700R4, 3.23 rear end, Flowmaster exhaust, $2500 stereo
1985 Camaro IROC-Z
28 is the overall tire height and the 11.5 is the section width, the widest part of the bulge as measured on the recommended rim width.
87 Formula 350 14.81@91.64
98 Z28 1LE 13.15@107.59
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1972 Corvette
I hope you make about 600 pounds of torque if you are going to use a 28 inch tire with 3.23 gears. ![](https://www.thirdgen.org/forum/biggrin.gif)
'91 Z28 Blue/Silver ZZ4/ZF6
328.4 RWHP 363.5 RWTQ
I have no intention of using slicks at all. I was just curious as to what the sizing was on them
1985 Camaro IROC-Z
1985 Camaro IROC-Z
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The ET drag and ET Street tires are a little different in the measurments. Since the ET Streets are a DOT approved tire the width (11.5) is the width of the tire at the sidewall bulge. The ET drag if using the same 11.5 size is the width of the actual tread.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.233
Best MPH on a time slip: 117.87
Best corrected MPH: 125.46
Best 60 foot: 1.662
Racing @ 3500 feet plus density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
TheTraut88
09-07-2015 05:22 PM
1Aauto
Sponsored Vendors
09-02-2015 01:35 PM
