Will a Weiland Stealth Manifold/Holley Carb, and a 3in Open element fit
under my stock Camaro hood? I just ordered a Stealth intake and was wondering if I am going to have clearance problems. I also have a Holley carb and 3in. Edelbrock Air cleaner with an indented(forgot the right name) base. Will this fit under a stock Camaro hood
[This message has been edited by Ray86V8SC (edited July 28, 2000).]
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
You mean a drop base aire cleaner? I have an Edelbrock Performer Intake, Stock TBI, and a 3" K&N open element(non-drop) and it is really close it make and indentation in the hood insulation.i don't know how much thicker if any a Carb is than my TBI But I would assume it's the same size. So you will be close, the Weiand prolly sits as high if not higher than the Edelbrock I have. You will most likey have to cut the Hood insulation out or cut a hole in it for your air cleaner to sit in.
Later,
lars
'92 RS 305 TBI
K&N Open Element
Ultimate TBI mod's (thanks Pablo)
Cam[.442"/.465" x 218*/224* @ .050", 10:1 Hypereutectic Pistons
Performer Manifold
Shift Kit, Corvette servo,
and 2800 Stall Trans Specialties Converter,
Gutted Cat, IAT Resistor
MSD Blaster Coil, Accel Cap and Rotor
[This message has been edited by lars92RS (edited July 28, 2000).]
Later,
lars
'92 RS 305 TBI
K&N Open Element
Performer Manifold
Car: 82 camaro SC
I have a stealth intake, holley carb, and a 14x3 K&N drop base air cleaner. It fits without a problem. Just make sure you don't have an extra long stud sticking out of the carb to attach the wing nut and you should be fine.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
L98GTA87
08-11-2015 06:55 PM
