My car is making the sound a supercharger would make..what gives?
Ok, so i get out of work today, get into my car and fire it up. I rev it a bit as i always do and notice that when i do, i get the whistling sound you get from a supercharger. So i stick my head out the window and rev it louder and sure enough, the sound increases and i think that by some act of ***, a supercharger is under the hood (of course its not sadly). I got home and popped the hood and had my mom rev the engine while i listened...it doesnt really sound like a belt or anything like that although one of my friends said it might be a pulley. It almost sounded like it is coming from the tbi itself, i'm not sure till i look at it when its daytime out...so...any ideas on what the cause may be?
Note: it doesnt whistle while idling, only while giving it gas
Note2: The car, while i didnt really get on it coming home, ran fine w/ no noticeable problems....OH, and my check engine light has been coming on a lot more as of late (gotta pull the codes tomorrow)
1 Post
Car: 1986 IROC-Z
Have you done anything to the intake tract? Last summer I installed a homemade ram air setup on my TPI intake, and if you listen closely you can hear rushing air. In fact, this morning when I started up my car I got out to get something from the garage. Since it was idling a little higher than normal (not in closed loop yet), the rushing of air was very pronounced -- even caught me off guard at first, until I realized what it was!
My point being, maybe it was there all along and you just noticed it now.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Air cleaner come loose maybe? i know when i take mine off, the whistle from my carb gets alot louder because the air cleaner muffles it.
Car: Death Mobile
Engine: 666 c.i.
My immediate reaction was the alternator also. Mine too started to whine when it was going. Do you have a voltmeter or idiot lights? If you have a voltmeter, you will see the voltage has dropped, and in a short while ....
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Turbocharged cars wont produced boost when just revved up. Well, myne doesnt anyways.
I'd check ALL the vacuum lines going to the TBI, I had a whisle in my engine, AND I ALMOST KILLED MYSELF TRYING TO FIND IT... I checked everything, it turned out that it was a vacuum leak by the EGR valve..
good luck
good luck
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Originally posted by jeff1367
Ok, I'm thinking power steering pump. Check the fluid level, My friends Iroc made a supercharger-like noise when he had a leaking PS hose and the fluid was low.
Car: 83 Z-28
Engine: LG4 305
my escort has been doing that but only when i get up to like 4000 rpms. sounds like a wistle from a vacuum but people think its a turbo. i dont mind them thinking that either.
but you can check the power-steering ALL THE TIME... put the car in park, and turn the wheel from side to side, if the whining gets louder when you turn the wheel, THAT'S YOUR PROBLEM, but it will also get louder as you accelerate if you're going in a straight line.
one other thing you should check... look at the water pump after the car warms up... if there is ANY anti-freeze on it or coming out of it THAT's YOUR PROBLEM... if the bearings in a water-pump go out,,, trust me, you WILL hear it (sounds like a super-charger, hmmm) keep an eye on the temp gauge and check your power-steering and all your manifold vacuums, either that or just put a SUPERCHARGER on your car so you don't notice the other sound..
It's a whistle hes describing, not a whine.
A whistle sounds much different than a whine. A whine sounds like a ***** who just got beat by my moms Caddy.
It's a vacuum leak. I went through the same thing last year. Took forever to chase it down, I just replaced 90% of my vacuum lines and it vanished.
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
Shut off the engine and disconnect the plug in connector to the alternator, start the engine and see it the noise go's away. If 1 or more diodes go out it will make the superchager noise your talking about, the volts will also be down some and the alternator will get very hot to the touch very quickly after it's started.
Before you shut the engine off, just put your hand on the alternator housing. If its a bearing just starting to act up you will feel the vibration coming right through your hand.
Steve
Steve
Car: 2001 Trans Am WS.6, 1985 Trans Am-RIP :,(
Engine: LS1, 305 TPI
Transmission: 4L60E, 700R-4
I had the same whistling noise last night. My voltmeter was also low. This mean my alternator is dying? After a couple hours it went away. Now it seems to be fine and the voltmeter is at its normal spot. The battery is charging normal now. So is it the alternator?
Matt
Matt
Two tools can be really helpful finding out where sounds are coming from. A length of hose held to your ear acts like a stethoscope to help pinpoint vacuum leaks and such. When trying to isolate mechanical whines, etc, any type of solid metal bar works well. Hold one end against a suspect area and listen to the other end. I use a 12" screwdriver.
MikeS
p.s. since we're voting, I vote alternator...can we make a poll?
MikeS
