Brights stuck on!!
Brights stuck on!!
91 rs with tilt and SIR... i was pulling the turn signal to turn the brights on, they went on and then i go to turn them off but when i pull the lever is moves but nothing clicks and now when i have the lights on the brights a on... how i can fix this?? what went wrong
It sounds like to me that your dimmer switch went bad.
In a car that i had , mine went bad ,but it was the kind on the floor, changed it out and it worked fine.
Im not sure how you would change the one on the column
Car: 1988 Iroc-Z
Engine: 5.7 TPI
Transmission: TH-350
Axle/Gears: 12bolt/4:10
The headlight switch is probaly stuck on the high position. I had the same problem, I'm not sure if your switch is located in the same place as mine, but it is supposed to be connected to the steering column near the ignition switch. A steel rod in connected to the switch and to the turn signal lever. When you pull the lever it pushes the rod into the switch, which is a switch to switch between high beams and low beams. You can manually push the switch to turn off the high beams. The switch might be stuck or the rod connected to the turning lever is loose.I just put a manual switch under the dash. Or maybe the high beam relay is broken and needs to be replaced.
Car: 1991 Firebird
Engine: 383 stroker
Originally posted by Vader
No click probably means the switch isn't being engaged. Try tilting your column all the way up or down to "click" the high beams off, then adjust the position of the dimmer switch.
dbrochard
09-25-2015 04:56 PM
