Where to get glyptol?
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I hear everybody talking about this glyptol in painting lifter valleys but where do you get it from?
Car: 4
Engine: 6
Transmission: 5
Electric motor rebuild supply places...
All it is, is GE's tradename for electric motor varnish. Lots of similar products will work as well or better. For all I know, GE might not even sell it under that name any more; somebody put it in one of the hot-rod books a couple of decades ago, by name, so now it's part of the "lore", whether it's really the best or not.
RB pretty much covered it. I haven't seen the original for years now. If you go searching for it, the name is spelled "Glyptal", and the only color I ever saw was red. It came in a a red and white striped spray can or non-reduced (brush) formula up to a one-quart size. The last thing I saw used for touch-ups such as Glyptal (before more or less getting out of the business) was a black, high-solids, epoxy enamel that was a water base. Motor/trnasformer shops nearly all went to clear water based insulation varnish in the '90s, and it turned the triple dip/bake time from a fast one-day service to a minimum of two, just for dry time. Isn't technology marvelous?
I use a thinned oil enamel on lifter valleys, heads, etc., but I've notived that synthetic will slowly strip that away. I wonder how Glyptal enamel would withstand modern synthetics.
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
I just polish my lifter valleys a little with cartridge rolls, it takes all the rough area's off, that helps oil drain a lot and you don't have to worry about paint flaking off.
