Timing Chain Set-Up
Old 07-27-2000 | 02:16 PM
Formula92's Avatar
Timing Chain Set-Up
Everybody has timing gears exp for roller cam from factory, what gives. I need some examples by manuf please.
92 Formula,305HO,Factory Oil cooler,Hyper-Tech Chip,Hyper-Tech Coil kit,Dual-Core Split-Fire wire set,Hyper-Tech Airfoil,Accel Fuel pressure guage mounted on fuel rail,Crane Adj Fuel Pressure Reg,March Performance Pulley set,Four Wheel Disc Brakes,WS6 Package,Dual Convertor Exhaust,3.42 Gear/w POSI,5Speed Borg Warner Tranny,Center-Force2 Clutch Set-Up,K&N Filter.
Old 07-27-2000 | 02:21 PM
kevinc's Avatar
Car: 1982 Z28
I bought a Cloyes piece from PAW (advert in just about all car mags) designed specifically for roller apps. Cost $70 for double-roller piece, comparable to non-roller price.
I don't have the part# handy, just specify '87-'92 SB Chevy and it should shake out the right part. Check their part# against, say, '82 to be sure.
-Kevin
1982 Z-28
See http://www.mycar.net/mafb/registry/detail.cfm?id=276 for details
Old 07-27-2000 | 02:40 PM
Ponchojoe's Avatar
I bought a Milodon Premium Roller Chain for my 1988 L98 TPI from Northern Auto Parts.
Old 07-27-2000 | 02:42 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
Jegs has
Dynagear #328-78150 and Cloyes #220-9-3145 both SB chevy with OEM roller
1985 ASCD Ram Air Trans Am
GM Performance Parts 350, LT4 Hot Cam, Edlebrock Air Gap, Edle. 750
5 spd, 3.70, so much more....visit
http://www.execpc.com/~karpsta/home.html
to find out more
Vintageracer
01-10-2020 06:33 PM
drewdock87
South Central
08-18-2015 10:02 PM
MY87LT
08-17-2015 09:43 AM
Leggman1
Brakes
08-12-2015 09:39 PM
Quick Reply: Timing Chain Set-Up
