What are the diffrences between these two heads?
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
The heads I am talking about are a set of 450's and 416's. They are both 305 heads. I know the 450's were a earlier head but is there any physical diff. (flow capability) between the two?
The '450 castings are "Smog-Dog" heads, with likely smaller valves, certainly larger chambers (lower compression), and probably runner designs that go along with those drawbacks. If you can get the '416 castings instead, it's a definite improvement as a starting point.
Hotrodboba400
12-10-2019 07:07 PM
92projectcamaro
01-18-2016 08:00 AM
