Shaking at 2K on tach...PLEASE read!!!
This is driving me crazy. First of all I have an 88 GTA. 5.7 TPI stock. I got the car about 6 months ago and have been working to get it running where I think it should be. My first nagging issue is an off idle hesitation. I checked the archives but am still stumped. Did all the basic tune up stuff as far as plugs, wires, etc. I replaced a bad O2 sensor, adjusted the TPS to .54 and the computer was cleared of codes. Timing is 6 degrees, fuel pressure is 44. This hesitation happens only off the start.It happens if I feather the throttle but is VERY noticable if I go mid/full throttle from a stop. Along with that is a bad shudder/shake in the acceleration at 2000 RPM. This occurs at any speed. It's to the point I hate seeing that 2 coming on the tach. 1800RPM fine....2200 RPM again fine. This is driving me absolutley insane. Please give me some ideas of what else could be causing these probelms! Any responses would be greatly appreciated.
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
check for burned plug wires or bad plugs
Put a light on each hole at 2k and make sure they are firing
Ok, I guess it's time to show off my lack of knowledge in regards to this car. What holes are you referring to in the above post? And what type of light....a timing light or will any light work? I'm sorry if the answers to these questions should be obvious. I am just starting to learn about this engine which makes the problems I am having all the more frustrating because I don't know what steps to take to resolve them. The plugs and wires should be okay due to the fact they are new, but I will check them as well.
Car: 89rs
Engine: 400Sb
sorry.. maybe I presumed too much..
it was early in the morning ..
Use a inductive pickup timing light on each plug wire one at a time when it experiences this abnormal condition. Thats a good start.
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
How old is the gas?
My car used to shake from 1750-2000rpm, with very old gas in it. I ran it to empty and filled it up with 93 octane. Now it runs fine!
Black_Widdow
02-19-2004 09:42 AM
