Anyone used Loctite on Header Bolts
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
Like it says, has anyone ever used Loctite on Header Bolts?
I called Loctite and they said it may be flammable over 300 degrees. I don't think a little bit on my bolts could hurt.
Anyone?
Anyone?
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i never did but always thought about it. but if its flamable then i wouldnt risk it. what if you spark plug wires burst into flames where would the flame go? to the rest of you engine most likely. i am skeptical of that. i had a friend loose his 69 chevelle because of leaking oil that burst into flames.
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Originally posted by james_85Z28
dab a little permatex on the threads to help stop them from backing out.
Just use ede's method or buy Stage8 bolts from Jeg's or Summit.
BTW ede..... what gauge of wire do you use?
Originally posted by V8Astro Captain
I haven't heard of drill and wire method. Could someone elaborate?
If one bolt starts to loosen, it "tightens" against the other.
Perdy neat, huh??
Car: 90 GTA
Transmission: TKO
Axle/Gears: Stock
BTW ede..... what gauge of wire do you use? [/B]
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
actually what our good friend ede is saying is true and it is "da bes" solution.
i did the same myself and is kinda' "fire and forget", being an aviation mechanic i got access to plenty of "lockwire" but limited to my toolbox, but i believe it can be found ...somewhere... , if you have a friend technician either on the air force or on an airline, he will be glad to provide you with what you need, i recomend gauge 0.32 (just ask for "lockwire 32"), it is already stainless steel and very easy to work with.
i hope it helps brother.
Fernando.
Fernando.
Car: 2003 Porsche C4S
Engine: 3.6L
Transmission: 6-speed Manual
Originally posted by AJ_92RS
Uhhhhhhhhh..... that's who makes Loctite.
Permatex as in silicon.....
I think you mean siliCONE.
I don't think gasket sealer would do much except melt.
I have enough trouble just getting to some of the header bolts, let alone trying to safety wire them. Don't care what the "experts" think. I use red loctite and it works like a champ. Never have lost a bolt that I used loctite on.
Locktite will keep the bolts in when the car is cold, the the lock washer idea has some merit. My header bolts stayed in longer with them. Make sure you use stainless though.
Mark
Originally posted by Mark W. Winning
I thought Silicone was for *****?????
:sillylol:
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
It's when you drill holes through the bolts, then feed a wire and attach it like this.
Perdy neat, huh??
Perdy neat, huh??
Car: Bee-Bowdy
Axle/Gears: fo-tins
Originally posted by Odyssey
the "right stuff" that comes in a can
It's expensive, but if you're like me then you can't stand to see any leaks.
Perdy neat, huh??
Perdy neat, huh??
Ben
Car: 1986 Firebird
Engine: 2.8 V6
You twist the wire back on itself. At the furthest end, you make a loop, slide the safety wire thru the bolt... almost like when you start to lace up a pair of sneaks. Then you start twisting the wires together. Usually a "safety wire tool" is used; it has a "spinner" on the end. Once you get to the next bolt, you thread one of the wires thru the bolt, the other "around" the head of the bolt, and then start spinning the wires together again. When you're done, after the last bolt, spin the wires together for a half inch or so, and cut the wires.
'Course, I've never done it before, just seen pics, so someone feel free to correct me!
tom1985
04-19-2016 07:55 AM
LT1Formula
20
11-14-2015 12:02 AM
hectre13
09-08-2015 03:38 PM
