spark plug boots with headers.. which ones?
Car: 1988 Camaro
hooker shorty headers, and cut to lenght MSD 8.8 mm plug wires.
What boots will give the best/most clearance w/o having probs with touching the headers?
MSD's multi-angle boots or 90 degree boots?
BTW if it matters the car is a 88 camaro, 71 350, 65 327 heads
John
John
Car: '94 Corvette
I use 90° with my Hooker shorties. Steer clear of the multi-angle cause there huge...
I still use boot sleeves, cause even with 90°'s it's close...
Summit # MSD-3311
Ron
Summit # MSD-3311
Ron
Car: 1988 Camaro
Thanks guys... 90 deg. boots it is.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I use a mix, some places 90's fit better, other the straight mulita-angle, fit better.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Originally posted by Vader
Or you can install the LT1 style heat shields:
T.A. One Two,
Spark Plug heat shield - GM P/N 12163646 $1.71 ea.
Cedarburg, Milwaukee, West Allis, wherever you find your closest Checy dealer - except Braeger - they sell too many Fjords...
Shopping on-line at SDPD200.com is easy, too.
Car: 1987 Black IROC-Z (SOLD)
Installed them on my plug boots with SLP headers. This should solve the burnt boot problem for me. Thanks for the heads up Vader on the posted picture & info.
89 formula TPI
09-07-2015 11:06 AM
