View Poll Results: What kind of oil do you run?
biological
44.44%
synthetic
48.15%
bio / synth blend
7.41%
Voters: 27. You may not vote on this poll
What kind of motor oil do you run?
Car: 1985 Camaro IROC-Z
Engine: 350ci V8
Transmission: 700-R4 auto
I'm doing my rebuild in a few weeks. I want the longest life and best performance possible. What kind of oil do you guys use?
Valvoline 10w30. i change it about every 2500 miles. if it was a new motor i'd probably go with Mobil 1 synthetic which everyone says is one of the best.
by the way, orlando here also.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Originally posted by Marshall89ws6
run regular oil during break in and then switch over to synthetic.
I just switched to synthetic in my 140K 305. So far for the last maybe 400 miles it hasn't started leaking that I've noticed. I'm gonna keep an eye on it though. It still smokes for the first 3 seconds I start it up, cause the valve seals leak a bit but it doesn't seem worse than before.
I was running synthetic only on my motor. Ive concluded it wasn't breaking in with synthetic. 4000 miles and it still burns alittle oil and the oil gets nasty quick. Im gonna switch to regular castrol GTX for a few changes and see if it stops. If it does im switching back to mobile 1 synthetic.
Car: 1989 Trans Am
Engine: 355 HSR
you have to run regular oil for a while when you first break it in or the ring won't seat... that may be whats causing yours to smoke
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
synthetic here when I have the money
and after I get my turbo motor in all the time
prolly going to run castrol syntech
what are you guys opinion on castrol sytec vs mobil 1?
Car: 1986 Firebird
Engine: 2.8 V6
Another vote for Valvoline 10w30... with 248,000 miles on my original motor, I'm not moving to synthetic! I'd have so many leaks, it'd be like a watering can.
Car: 91 z28
I'm running castrol 5w30 for the first 3500 miles. I was going to switch to castrol syntech after that. What do you guys think?
BTW- I change my oil very often. It is not a daily driver. I might put 2500-3000 miles on it this year. The motor went in last march and I have just over 2200 miles on it. I changed the oil 8 times.
Navy8125
08-21-2015 09:32 AM
92camaroJoe
08-13-2015 06:07 AM
