your opinion and sound clips **Please**
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
the cam choices i have been looking at are pretty close and i have a deal on this one, and i would like a very lopey if not choppy cam...
Comp Cams 282 hydro roller
230-exhaust-236
int.510/exh.520 with 1.5s
and all of these mods will be don't at the same time...
-holley stealth ram
-AFR 195s heads
- Hydro rev (springs are up in the air right now give some idea's)
- S10 stall (mainly because I have one)
- 36lb SVO low injectors (main because I have them)
and the mods in sig
after mods i will get a video clip on the idle lopeyness, but i would really like to hear some sound clips of your babies, and cam specs, EFI would be nice but i don't mind and others, ..
any one with this cam CHIM in please your opionion would be apprecaited....
PS i am searching, and searching the forums, but the sound clips are so far apart and weak, this tread is needed for anyone else that would like to hear some cams before the waste some money on a cheesey one....
230-exhaust-236
-holley stealth ram
-AFR 195s heads
and the mods in sig
Transmission: 4l80e
after hearing MATT87GTA sound clip of the LT4 hot cam
i might go for that one....
try here: http://shootmyphoto.com/misc/xe230-236_Edel_RPM.mp3
thats what it sounds like... lot's of lope!!!!!! but like i said, if you hated the interior panels vibrating and such, then i don't suggest this cam.. i wish i had went smaller now.....
Car: '87 Camaro LT
Engine: 355 L98
so you're building your engine based on the sound it'll make? you should pick a cam that will work with your other engine components (heads, intake, etc.) and their best rpm range instead
Here are some sound clips I found of LT1s, they are not the best quality though.
Here is a 224/230 cam:
http://www.fierolt1.com/mm/Xtreme224_230.wav
Here are two of the CC306, I think it has the 230/236 duration but I am not sure:
http://www.fierolt1.com/mm/cc_306.wav
http://www.fierolt1.com/mm/306cam.wav
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
hit the second link of my sig, and find the .wav file.
hit the first link for my setup.
let me know whatcha think...
brady
brady
Re: your opinion and sound clips **Please**
Comp Cams 282 hydro roller, 230-exhaust/236 int .510/exh.520 with 1.5s
-holley stealth ram
-AFR 195s heads
-holley stealth ram
-AFR 195s heads
Idle/Low RPM.wav
There is almost no noticable idle lope.
Transmission: 4l80e
they all seem, great really, HITHERE think anything along these lines will be what HITHERE want, something else HITHERE didn't metion is that HITHERE will be converting to SD after HITHERE get the car running well with MAF (HITHERE burn my own chips) anyone have any vacuum readings for idle at 700rpm
