Which carb to manifold gasket to use for Edelbrock Performer RPM Air Gap??
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I will have the Edelbrock Performer RPM Air Gap intake manifold (#7501) and a Holley 4150 700 CFM double pumper carb (#4778) on my motor. What gasket do I use between them? There are so many that say will fit the 4150 carb, but I don't know what size to get for this manifold. I assume I should get one with an open center, like for a single plane manifold, because this manifold has a big "slot" cut out in the middle, so it's almost a single plane. Correct? Any sizes or part numbers would be greatly appreciated. Thanks in advance.
theshackle
09-17-2020 08:26 AM
86IROC112
08-17-2015 02:00 PM
