Edelbrock Fuel Pump ?
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
Has anyone used an EDELBROCK SBC STREET FUEL PUMP #1721
In there car? What i was wondering if you had to do any mods to make it fit.I know yo have to get rid of the return line to the gas tank cause it doesnt have it on the fuel pump.Im using the fuel pump on a carbed 350 with no computer....
Car: 1985 Trans Am
Axle/Gears: 3.70
I have one on mine. No real mods but you'll have to experiment on how to get it to fit, cause of the triangle brace that kinda interferes. You'll need to be real creful on where to rusn the lines also, cause the steering runs real close. I didn't pay attention the first time and ended up ripping off the fuel line first time I turned the wheels. DOH!
Don't waste your time with the bottom feed adapter, it won't work and is near impossible to get to seal properly.
Car: '94 Corvette
Ha Ha, that was the only way I could get the Edelbock(Older Carter) pump to work (AN fittings!), was with that bottom feed.
Never sealed, always leaked. This caused my car not to get over 5000 rpms.
The newer Holley pumps are the way good. It allows you to offset the input & output, unlike the Edelbrock in which the 'in & out' are directly across from each other.
Heres a pic
Ron
Heres a pic
Ron
Car: '94 Corvette
How about a link...
They range from 80-170GPH...
http://www.holley.com/HiOctn/ProdLin...SFP/FMSFP.html
BTW: I do believe these pumps are replacing the older ones sold under the Edelbrock name. You'll notice that the top hafes are almost identical.
Ron
Ron
Ron
Ron
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
