you think cc305 cam is right for me?
Car: 92 camaro
Engine: 383 stroker
Transmission: probuilt 700r4
i have a 383 with afr 195cc heads lt1 intake 7730 sd ecm 373 gears 2600 vig stal 10.5 compression hooker 1 3/4 long tubes mufflex exhuast you think cc 305 cam is good for me or what do ypu suggest thanks guys
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Is that a comp cams 305? If it is, thats way to big try a 270-280 i wouldn't go bigger then 292.
Car: 82 Z28
Transmission: TH350
LT1 intake? Are you going with TPI? If you are hell no that cam iw freakin huge. You can't spin the motor that high.
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
CC 305 would be a great cam with your setup. Just get some custom tuning and you should be all set.
There's alot of LT1 guys at CamaroZ28.com running that cam.
Car: 89 IROC
Engine: 350 Carbed
Transmission: WC T5
Seems to be way too much duration for a computer controlled car....Just don't fall into the bigger is better trap, play it aggressive yet smart..
Mandangelo
Mandangelo
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I don't know what you guys are smoking, but I'd like some of it please.
I'm running 230-236 .604-.608 and friends are running the ZZX cam from TPIS which is 240 .050 duration. All the cars run fine. As long as you modify the chip, your all good. I don't think there is a limit to the size of a cam, just the ability to tune it.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Also remember that the added cubes reduce the power peak rpm. Mine peaks at 6000-6100 and so does the friend's car with the ZZX. Both are 383's. The CC306, the XE230-236, XE236-242, and the ZZX are all good choices. Call Cam Motion and have them grind you a custom cam, or call comp, they will grind you one slightly cheaper. You don't have to pick a cam out of a catalog anymore, it's about the same price for a custom grind.
Car: 4
Engine: 6
Transmission: 5
It's a little bit much for a 350, but probably a good choice for a 383. 220°/230° with the longer stroke ought to behave just about like 214°/224° would in a 350.
If you don't mind some chip tuning the 306 would give you some extra top end. Unlike TPI, with the LT1 intake you can actually benefit from setting the motor up for higher RPMs.
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
i would say that the CC305 is too small... with that intake you will be able to spin it up to 6500 easy... a 305 is a good cam for a mild headed 350 so it would be somewhat small in a 383... i would do the CC306 or the 230/236... but that is just my $.02
