Metric fuel line fittings
1 Post
Car: 91 RS Camaro
Engine: 305 TBI
Does anyone remember the size of the fuel line fittings that convert the line to an fittings? I think they are 16 and 14 but can't remember the part numbers. Any help would be greatly appreciated. I want to order them and can't find them.
there's unlimited ways to adapt AN fittings to the factory lines. An is size like it's in 16ths of an inch, that is -8 is 8/16 or 1/2 inch. measure your line with a caliper or open end wrench and go soemplace the makes hydrolic lines and they should be able to hook you up.
1 Post
Car: 91 RS Camaro
Engine: 305 TBI
I know but, since we can't do a search lately I can't find the article that told what size adapter was used with the fuel line in the engine compartment. I think I have found it but not sure. I think it is 16mm x1.5 and 14mm x 1.5. They are $5.95 from summit. I went ahead and ordered them and I just hope they fit. If not I have wasted $12. The part #'s are EAR-991954 and EAR-991955.
1 Post
Car: 91 RS Camaro
Engine: 305 TBI
Hey, do you know if those will fit the lines too? I am thinking those are for the back of the TBI. I don't know yet what will be needed for converting pipe thread to AN.
Car: check
Engine: check
Transmission: check
http://www.holley.com/HiOctn/ProdLin...A/9894DBH.html
9894DBH Female 14mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
9894DBJ Female 16mm x 1.5" to -6: Fuel Injection Female "O" Ring Seal
991954 14mm x 1.50" to -6: Power Steering / Fuel Injection - "O" Ring Seal
991955 16mm x 1.50" to -6: Power Steering / Fuel Injection - "O" Ring Seal
RBob.
theshackle
03-05-2017 06:37 PM
AkDrifted
08-17-2015 07:45 PM
