5.0 TPI rev limiter
5.0 TPI rev limiter
I have a 5.0 TPI 91 Z28. According to the tech article on this web site, Z28's "do not have the "governer" to contend with." If this is true, why do I have a rev limiter that kicks in at 110mph? Is it basically disabled the same way as the TBI's... Can anyone help me? Thanks...
Car: 99 Formula
Axle/Gears: 342
A Governor is different from a rev limiter. A governor will limit your top speed, where as a rev limiter limits the engine's rpms and will cut spark( I do believe).
I could depend on your cars gearing at about 4500-4800 RPM a stock TPI will run out of air to feed the engine so if your in 3rd gear and @ 4600rpm and 110mph it my feel like a governer.
Just my guess on it, not sure.
I should ask if it is a 5 speed or auto, G92 or no?
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Yea, your motor is probably just running outta juice... not enough power to keep accelerating.
Car: check
Engine: check
Transmission: check
Re: 5.0 TPI rev limiter
Both speed and rev limiting was accomplished by cutting the fuel by setting the injector pulse width to zero, all from within the ECM.
RBob.
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I agree with RBob, check your stock wheels if they ar 15" then you probably have a speed limiter. A simple custom chip will fix the problem.
BTW. Yes it's a problem before you fix your speedo and 112 mph on the speedo = 92 mph in real life w/ 3.73 gears and all your friend's in 110 hp sh*t boxes start beating on the highway.
theshackle
09-17-2020 08:26 AM
Iroc8t8
08-26-2015 08:14 AM
Sanjay
08-12-2015 03:41 PM
