What are these connecters for?
1 Post
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Okay I have no idea what these connecters are for?
This a carburated V6 2.8 so they may have been intended for a fuel injected model I don't know :/
<BR>
<BR>
<BR>
<BR>
1 Post
Car: 1984 Firebird
Okay was thinking it looked like the MAP sensor connector, thing is, does the carburated V6's have a MAP sensor?
oops that blue and not green..sorry about that...disreguard my post as i think i am now color blind oh well hope i did'nt confuse you on that...I do think the carbed V6 had a map sensor on them but i think the connector whould be green but dont quote me on that, i am not at the shop at this time to verify that statement...again sorry for the misinformation
Car: 4
Engine: 6
Transmission: 5
Right, it did; but the MAP sensor is over on the firewall behind the brake booster, has a similar plug except not blue. The baro sensor was usually mounted on the underside of the cowl lip right above where that white tie-wrap is, at least in V8 cars, I have no clue if it was the same in a 6-cyl car as I have never even touched one that I know of. Might even be the same sensor for all I know.
1 Post
Car: 1984 Firebird
Well the second one couldnt be the electric choke, as that is I beleive on the other side of the engine and plugged in allready.
As to the MAP/BARO whats the difference with them? And I gues the flash messed up the color on the first 3 wire plug that is blue not green <bad me, had it backwards before>
Anyone with a carburated V6 who could take pictures to show me where that blue plug or/and the single wire in the other pic, Please let me know!
Car: 4
Engine: 6
Transmission: 5
MAP measures the pressure in the intake manifold, i.e. vacuum; baro measures the ambient pressure. Actual vacuum is the difference between the 2. This system compensates to some extent for altitude and weather changes.
That sure does look like the electric choke plug.
1 Post
Car: 1984 Firebird
Well once again, if someone can find me a picture of where either connecter goes, please let me know. I have been under the hood most of the day and can fine no place to plug either into.
Oh also, checking trouble codes I only get 12 over and over...I am assuming this is just a notification that the ECM is working?
No other Error codes come up...
