Alcohol injection kit
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I was thinking of doing something and wanted to see if anybody has done this or has theory on it. I am building a 383 with the stealth ram injection set up. I was wondering if I run that alcohol injection kit from www.smcenterprises.com would I be able to run like 12:1-12.5:1 compression on the street and still be safe with the timing. I have aluminum heads and fuel injection.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I'll be testing water/ alcohol injection on my 12.6:1 iron headed N/A motor this spring.
Shouldn't need a high pressure pump just to spray water down the carb though. But will use a high pressure pump/small misting nozzle if nessessary.
Water/alcohol flow can be as much as 25/30% of the total fuel consumption.
Going to be a lot cheaper than race gas.
Generic "Blue windshield washer fluid" is almost ideal.
It's 60/70% distilled water and 30/40% denatured alcohol.
It's like 1$/gal. The cheap stuff is the best, no detergents.
I built a detonation detecter (ears) as per instructions on
www.autospeed.com using RadioShack parts. easy to do.
Very effective for finding detonation.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Do a web search. There are lots of pages about it.
http://www.gnttype.org/techarea/recipes/alkyrecipe.html
here's one for turbo buicks.
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
