Header tube glowing red!!!
Car: 1990 Formula 350
Engine: L98 350
Only one tube is glowing. I just noticed it today could have been doing it for a while now. Just dont know. What causes this?
Thanks Gary
Thanks Gary
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Just one tube,? My guess is that one injector is dumping too much fuel into the cylinder. The excess fuel is being reburned in the primary, and causing it to glow.
Now sit back and wait for the "lean" crowd to come on in.
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Engine: L98 350
lol you are right. Well could it be that i am not getting spark in that cylinder so the gas is not burning. I dont know what to think, it runs really good has a small miss but runs good. how would i check to see if it is my injector or the spark in that cylinder?
Thanks, Gary
Thanks, Gary
Yes, could be weak spark as well. A quick search for 'how to test for weak spark" would save me a lot of typing
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Engine: L98 350
Check the voltage on the injectors while it is running or off, and what is it supposed to be?
Gary
Gary
Okay, let's keep ya on track as to what is happening with the cylinder in question...
Check the plug...most likely it'll be a little bit "sooty"...but why? Too much fuel or too little spark (discounting a bad valve causing exess fuel to pass through)?
Next, check the voltage on the injectors...my hunch is you'll always see 12v.....and that would be correct, because they always have 12 on'em until the ECM grounds the other side to "fire/open" them to allow fuel into the port.
You can diag the problem efficiently by...
1. Compression test. This will eliminate/comfirm a valve seating issue.
2. Injector balance test, this will tell you if that injector is dumping too much fuel.
3. Spark test. This will tell you if you are not firing the cylinder well enough.
Now...is it lean...I really don't think so..why? Well, in order to "glow" the tube, the heat from the combustion chamber would have to be sooooooo high, you'd probably melt the primary....Sure, if the primary was "red" just off the head, could be lean, but if there is any "length" to the "glow", 99.99999999% of the time, it'll be from unburnt fuel.
And just think about it, I'm guessing (may be my mistake) that "you just noticed" this...when you popped the hood...when the engine is idling. How the heck could an idling engine be so lean to glow a primary?...Impossible, IMHO.
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
i would venture to say its valve timing. either the valves are staying open to long or opening to soonand the spark ignites the fool as its exiting the cylinder
Hotrodboba400
12-10-2019 07:07 PM
