Why not use the '93 LT1 T56?
I am seriously considering a swap from my auto trans to a T56. I've been doing research and I know that the '93 is not preferred due to the .62 overdrive vs. the .50 in a '94-'97 T56 (the .62 is still better than the overdrive in my 700R4). I also like the lower first gear ratio in the '93. Other than the gear ratios, why not use the '93 T56?
The reason I ask is because a brand new '93 Tremec T56 (10236021) goes for ~$1700 where a new '94-'97 Tremec T56 (12558016) goes for ~$2900.
What makes the '94-'97 T56 worth $1200 more? Experts, please!
you also need to take into consideration what gears you have.. A .50 OD gear with my rear gears puts me going 70 at about 1500 RPMS. which with my current set up is not where i want to be.. also i hear the 94+ are stronger.
Please explain "stronger". Does that make the '93 "weak", or just not as strong as the newer ones?
edit: I just found some info...the '93 is rated at 400 lb-ft and the '94-'97 is rated at 450 lb-ft. So again, my question is why not use the '93 if it is still rated at 400 lb-ft? I would be pushing just over that figure, but not by much (25 lb-ft or so). And the car is purely a street cruiser and will not see harsh abuse...er, well not too much
Car: 2006 Silverado 1500
Engine: 5.3L
the 93 isn't weak, it'll probably handle 11's without any issue's. the 94 will handle just about all you'd want to throw at it.
Definately if you can, you can upgrade to viper internals.....that'll push it well over the 500 ftlb mark and you have room for future mods without worrying about the tranny.
chris
chris
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
How much do you think it cost to buy and install Viper Internals?
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
bigjay89gta
10-15-2015 08:04 AM
