Which is better? 4340 or 5140
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
4340 steel is the best
everything else is less than perfect. 4130s then 5140 is the quality of steel.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
4340 is the best.
Both are a Chrome Moly steel.
4340 is lighter
5140 has better corrosion resistance
http://www.scatcrankshafts.com/newslawone02.html
4340 is lighter
Car: 87 IROC L98
I'm assuming this is in a SBC.
A stock cast crank can easily take over 550 HP. There are a few prepped stock cranks that reach 700 hp. A nodular crank is stronger and can survive most buildups.
I've run a stock cast crank in my engine for the last few years. I just upgraded to a 4340 crank to reduce some weight.
LT1Formula
10-08-2015 08:34 PM
C409
09-23-2015 04:30 PM
LT1Formula
08-20-2015 09:36 PM
LilJayV10
Aftermarket Product Review
04-29-2002 08:22 AM
4340, 5140, batter, corrosion, cranck, crank, crankshaft, handle, power, resistance, steel, strong, stronger, transmission, witch
