what to get with $1000
Car: '84 Z28
Transmission: th2004r
what should i get for my setup below, i should have about $1000 to spend. $150 will be going to get a y-pipe bent and i'm going to get a new intake and carb for x-mas. i am thining about getting domed pistons to get my compression around 10.5:1. how much of an increase will raising the compression from 9:1 to 10.5:1 be, how much do you have to lift the engine up to get the oil pan off?
how much does it cost to have heads ported and polished and about how much hp will it give?
should i also get a new cam, i don't know if i have enough cam or not. i want the hp to be from about 2500 to 6000.
any other ideas? thx
right now i'm at about 200-225hp.
