Speed Limiter
Speed Limiter
89 305 tbi RS - Does it have a speed limiting chip? (device of some sort)... What is it? How can it be removed/replaced?
91 305 tbi RS - (new pistons, cams, roller rockers, headers, exhaust, 3 angled-valve job, it has a hypertech power chip, couple other modifications) Does this have a speed limiting chip? (or did the hypertech-chip replace that?) or...?
Try searches for something called a "VSS."
It's the thingy that tells the ECM how fast you are going. If you can cut it's cable, then you can go as fast as you want. Installing a switch is a good way to do this.
Look for the tech article at the first page on the site, like ede mentioned.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Keiran
Engine: T.P.I L98.
Transmission: TH350
Yeap, you are right. It will work fine with a stick, auto...it will work. Just may cause some damage in the long run.
UltRoadWarrior9
09-02-2015 08:24 PM
