Stupid tranny fluid question...
Old 11-24-2002, 06:55 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
I've been getting some converter/clutch shake from my car when I do heavy acceleration in a hard turn.....so I did the next logical step, and checked my tranny level when I got home.....(tranny warm, car in park with engine running). The fluid level comes up to the little hole at the end of the stick. Basically, I'm only showing about 1/8 inch on the stick, when I should be up around 2-3". So the question is, how much tranny fluid do I need to add, and what type?
Thanks,
-The Gunny
Old 11-24-2002, 07:02 PM
gruveb's Avatar
Car: 1989 IROC-1
Check your manual for the exact type.........I've got a 5 speed, but I think it's the same, Mercon III.
Just add about a pint or so and check the level again.
Old 11-24-2002, 08:55 PM
Nasty_Bird_'90's Avatar
I'd start with 2 qts. Then let the car idle and check it. Add accordingly. How long has it been since the filter was replaced? If it hasn't been too long, i'd do that too. If the tranny is drained, it will take around 9qts of fluid. If it hasn't been changes in 20k miles or so, I'd leave the filter alone though.
Old 11-24-2002, 09:26 PM
Car: 91 RS
Engine: 350 TBI
The tranny was rebuilt like 4K miles ago, so I'm pretty sure I need to go back and get the pan bolts retightened or something. I haven't got up underneath there to see if there's a leak, so I can't be sure just yet. I added some Valvoline Max Life Dextron III; about 1 pint, and it seem to help with the performance of the tranny(no more shaking), but when I got home and checked the level again, it seems to have made no difference in the level.
Old 11-25-2002, 10:18 AM
TGO - 10 Year Member
Vader's Avatar
There should be cross-hatched area on the dipstick face. The bottom of the cross-hatch is supposed to be 1 quart low. If you're not in that area yet, add a quart, run it through the ranges, and check it again.
If the trans was rebuilt 4,000 miles ago, you should be thinking about changing the oil in the next few thousand miles to get all the little "Klingons" out of there. BTW - They DID install a drain plug, right?
Old 11-25-2002, 12:13 PM
five7kid's Avatar
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Isn't the hatched area of a tranny dipstick one pint?
Old 11-25-2002, 12:32 PM
Car: 91 RS
Engine: 350 TBI
That's part of the confussion I'm having with it. I'm kind of getting the impression that the stick goes by pints, but when you fill one up, most people talk in quarts. Which is no big deal, seeing how 2 pints = 1 qt.....I think. I was really trying to get at what the measurement on the stick represent....pints or qts.?
Old 11-25-2002, 01:59 PM
five7kid's Avatar
Engine: LS1/LQ4
My car is in the parking lot, but I'm 1500 miles from the parking lot...
It should say "1 pt low" or something like that on the dipstick. Measure the length of the crosshatched area, and how far the fluid is below the "Full" mark; divide the latter by the former and add that many pints.
Service manuals typically refer to tranny capacity in pints. But, the ATF is sold in quarts, so pints capacity divided by 2 is how many quarts you buy.
Old 11-25-2002, 08:30 PM
Vader's Avatar
O.K. - I had a brain fart...
I should have said PINT, not QUART. I guess I'm suffering from cabin fever already.
Yes, transmission capacity is generally quoted in pints, even though it is normally sold in quarts. Cooling system capacitiess are usually quoted in quarts, but antifreeze is sold in gallons (since no one uses alcohol any more). And manual transmissions and differentials are listed either way, according to my reference books. I guess that's one thing the metric system has over the "old" system, except when you're discussing combustion chamber volumes, or smaller engines (like motorcycles and snowmobiles), or torque specifications. Isn't ANYONE consistent??
Old 11-26-2002, 01:24 AM
CamaroDriver's Avatar
I think bran cereal is supposed to help with that.
Thank the King. If it wasn't for his arrogance, we wouldn't even have a "foot" or an "inch"
And I've always wondered that to.... about measuring combustion chambers in cc's. But yet nobody wants to say they have a 5.7L. I want to get a sticker on my car that says I have a 1.5 gallon engine!!!!!! :sillylol:
I think you may have been thinking somewhat straight. The first dot from the bottom of the stick is ~1 quart low. I'd still only add a pint at a time though.
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
bjpotter
10-04-2015 07:48 PM
meeklay812
10-01-2015 03:46 PM
Galaxie500XL
10-01-2015 01:05 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: Stupid tranny fluid question...
