**warning** cam clearance pt 2.....
well the small base circle cam from comp is supposed to be here tomorrow....... if it dosen't clear then i don't know what to do..... to keep everyone up to date on what happend, i'm building a 383 stroker with the following..
scat 9000 series crank for 87 up 1 pc seal ext balanced
scat 4340 i beam rods with 3/8 arp bolts
speedpro lightweight 383 flattops l2491f-30
i had bought a comp xe282hr cam prt no 08-432-8 from jegs and the rods hit the cam pretty good when i was mocking it up..... so i sent it back to comp and they grinded me that cam with a small base circle.....
i'm hoping it will clear but somthing deep down gives me fears it wont..... but only tomorrow will tell........
wish me luck!!!!
wish me luck!!!!
New2Chevy
09-28-2015 12:35 AM
