EGR blockoff plate??
Car: 1988 Mustang GT
Engine: 302
Where can I get one? oh and that stupid ERE actuator thing (on the lower passenger side of the engine) is that easily removed or is it connected to anything in the motor?
You can just make one by cutting some sheet metal and drilling a couple holes in it. Sealing it with silicone or cut a gasket if you feel like it. I forget which I did, maybe both.
Engine: 302
that's what I was thinking .... I've got some 2024 aircraft aluminum.... you think it would hold up or should I use some sheet steel?
-dan
-dan
Car: 1982 Z28
If you don't feel like fabricating, Street & Performance sells EGR blockoffs in spiffy thick aluminum. www.hotrodlane.cc
monte87cortez
09-26-2015 08:10 PM
