Oil filter part number?
Anyone out there know the part number for the longer (read larger volume) oil filer for "86, 305 TPI. Any of the larger manufacturers will do. I can cross reference it. Thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
if you do not have the oil cooler then it's acdelco pf-932. if you have the cooler, then it's pf-35.
Engine: 360 HSR
ok that helps. but it's not as long as the pf-932. because the pf-35 is what comes on big block chevy. which is about 2" longer than the pf-25. the pf-932 is what comes on the GM very large trucks. like the c6500 series and dump trucks. which is twice as long.
Car: 04 GTO
Transmission: M12 T56
I'll admit outright that i've never used the super gigantor filter, always stuck with the pf-1218 or 35 depending on what the store had in stock. I've heard that the gigantor filter will come down to be basically even with the bottom of the oil pan, which is just a little too low for comfort for my taste. True if you somehow manage to take out the filter you are no doubt gonna wack some other stuff under there like the y-pipe, oil pan and maybe tranny pan to, but i still would try to avoid the extra quad-fecta (is that a word, lol) of wacking the filter too in that event.
And for those that think what i am saying is near impossible, think again. I trashed my Y-pipe, oil pan and tranny pan last winter. If my oil filter would have been at the level of my oil pan, it would have been gone too, making an already screwed up situation just that much worse.
Engine: 360 HSR
yes. with the pf-932 you will have a total of 6 quarts in the system. and yes. it is just at the bottom of the oil pan. the crossmember is lower than that. so, in order to hit it, you would have to almost take out the crossmember.
do you need that much filter? well an extra quart means that the oil will be cooler. you will have twice as much filtration. you don't have to. but it doesn't hurt.
1 Post
Car: "02 z-28
Engine: LS-1
Originally posted by TBI305Camaro
is that much filter really necassary? thats huge. could you run an extra quart of oil with that filter?
Car: 04 Vette
What good is an anti-drainback valve on a motor on which the filter hangs in such a way that it can`t drain back unless you turn the car on its side or upside down. I have used almost ever filter possible on my T/A and have seen no benefit or loss due to any of them.
1992 Trans Am
05-10-2023 07:19 PM
maroe624
04-16-2017 08:29 AM
Navy8125
08-21-2015 09:32 AM
