Dyno 2000, How does this sound for my setup?
1 Post
Car: 99 Formula
Axle/Gears: 342
Here is the screen shot of my setup with the new heads. Does this sound right? Any suggestions to get a some more HP out of it? A 700cfm carb gives me a few more HP.
1 Post
Car: 99 Formula
Axle/Gears: 342
Looks like Vortecs will be better, or should I just suffer a little now, in order to have it better later on, if I replace the cam?
1 Post
Car: 99 Formula
Axle/Gears: 342
Originally posted by Ed Maher
Yeah, but didn't it run like 15s?
Thats why desktop dyno shouldn't be taken too seriously.
Yes, that was with the stock Goodwrench heads, I'm still working the bugs out, obviously I should be running faster than that.
1 Post
Car: 99 Formula
Axle/Gears: 342
1 Post
Car: 99 Formula
Axle/Gears: 342
Re: hey
Originally posted by badgta
mark, what made you decide to go with the 270h cam???
the cam is really whats killing it..... can a hyd roller cam be used in that block without special parts like the 87 up's???
if so try a lt4 hotcam or comp 276hr.....
1 Post
Car: 99 Formula
Axle/Gears: 342
Originally posted by Xenodrgn
You know vortecs don't come stock with the bigger valves right?
Oh yeah,
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Originally posted by Aaron91RS
Your cam has 110LSA? You sure about that?
I believe they make a marine line of XE cams, however, that have a 112 LSA.
not bad mark, set up the vortecs with smaller valves, as the flow numbers are for the smaller valves. I found numbers on my 487 heads, and for me at least it seemed more cost effective to get a supercharger for max power.
I still think you have a major tuning issue myself. I have personally blown the doors off of mid 15 second cars and I have 1971 truck heads. I have the XE262 too. Can't you get different metering rods for the edelbrock carb? I know playing with that stuff on my quadrajet really made a difference.
Car: 86 Cutlass
Transmission: 200-4R
