What is the biggest you can stroke a 350?
really depends on how much jack you have to drop in it. 4" is pretty straight forward 4.125 or even 4.25 with an aftermarket block. do you want to fill it with grout? if so that would allow you room to grind more clearance into it. also rod to cam clearance becomes an issue, but like most things there are ways to get around it. what do you have in mind or was you just asking for gernal info?
Just in general, seeing what my options are. I want something besides a 383, cause that's what everyone has. Looking for something bigger. I was going to get a new block anyway, so I could always get a bigger block than a 350.
1 Post
Car: 99 Formula
Axle/Gears: 342
1 Post
Car: 99 Formula
Axle/Gears: 342
Haha! That really would be different. I want to be different, but still have all the perks of the sbc.
Now a 327 on the other hand is a bit different.
I am going to assume you weren't trying to be a d!ck by saying that.
95% of people who have something other than a 350 have a 383. I'm not asking for your opinion, I'm just wondering what my options are.
I am also considering getting a 400.
1 Post
Car: 99 Formula
Axle/Gears: 342
1 Post
Car: 99 Formula
Axle/Gears: 342
That's ok. Its hard to tell on the internet what people mean sometimes. No hard feelings
I know what you mean.
oh yeah, about that meet, check the link in my sig for the website i made, and email me buffshields@yahoo.com with name/thirdgen name/and aim if you have it, to be added to my maailing list for updates.
1 Post
Car: 99 Formula
Axle/Gears: 342
Originally posted by cdogc350
Car Craft magazine took a 350 and stroke/bored it to a 406.
I didn't want to mention it earlier cause I wasn't sure of the #, but I thought my borther had a 406 or something in his 84 Camaro once. bored .120 over, yes .120. and stroke I assume.
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
[QUOTE]Originally posted by Kevin91Z
396 is about the biggest people go with. Thats bored .030" over and a 3.875" stroke. (383 is 3.75" stroke). You could bore it .060" over instead. If you get a 400 block, you can go 4.125" bore and 3.875" stroke for 420 cubic inches ( I think ).
Speed-O-Motive lists a 397ci stroker motor with 4.060" bore, 3.835" stroke, and 5.7" rods. The rod ratio of this motor is 1.48 and the deck height is 9.025. I haven't found the ad yet, but it seems that Cat was producing a stroker kit for the 350 that offset ground the rod journals to the small journal size and they were getting 411 ci or something very close to that. I will do more research and get back to you.
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
Re: What is the biggest you can stroke a 350?
What is the biggest you can stroke a 350 block?
Re: Re: What is the biggest you can stroke a 350?
Originally posted by 1991tealRSt-topGuy
how big is your wallet? :sillylol:
That is the truth. If money is no object, i just got done building a 487 inch smallblock. It makes close to 1000 hp, NA. Was not cheap however.. A more realistic big smallblock is a 434. Easy 800+ hp, and not quite as much $$$$$
What is a 427? Stroked 400 or is it a different bore also? I realize that 434's are stroked and bored 400 blocks. And also while we are at it, what is the bore and stroke of a 396 big block?
Engine: 5.0 TBI
Transmission: 700R4 Auto
400 is 4.125" x 3.75"
396 is 4.096" x 3.76"
454 is 4.25" x 4.00"
Oh and a correction to a previous post: 4.125" bore and 3.875" stroke only yields 414 c.i.d.
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
Here is what happens when you take a stock 400 block, bore it .030, add a Callies 4.00 stroke crank, Oliver 6.00 rods, and JE 13.5:1 pistons-(434 CI). Watch for the fan belt-new deep groove pullies are now installed-the MSD pill is 7K.
434 85 Z28
85 Z28
434 CI 640H/622T engine dyno
T-56 with Tilton ctch/mc
9" Ford w/3.70 gear
:hail:
434 85 Z28
85 Z28
9" Ford w/3.70 gear
:hail:
Originally posted by MuttandJeff
The 427 is 4.25" bore x 3.76" stroke (standard and tall decks)
427 a big block or small block?
