WTF Car is Dead
WTF Car is Dead
I hate this week. First I had a brake line go out, had to replace that, now after it has been running fine, I come out this morning and its dead.... Well, I just put a new starter on less then 6 months ago from Napa so that shouldn't be it. I think its the stupid battery from Autozone, when I turn my lights on and try to crank my lights go dim. But I don't have enough power to even crank, when I turn my key lights come on, security, and radio all come on... So what do you guys think??
Oh another crappy thing I found was standing water in my trunk, about 2-4 inches worth WTF?
If you turn the lights on and crank, the lights will dim, even on a brand new battery. if all you accesories are working, its the starter or wiring at fault. ive seen starters go bad a week old, not every starters the same, especially rebuilt ones. Use a multimeter (if you have one) and put the positive on the small terminal on the starter and the neg. on a good ground. have someone crank...if you get battery voltage to the terminal, you have a bad starter ....if you dont, its bad wiring or a bad relay.
Linson
08-21-2015 02:12 PM
