power sterring pulley wobble???
Car: 91 rs
Engine: Carbed 355 CR 9:1 xr276 cam
Transmission: 700r4 2600 stall
My power steering pulley has a wobble to it I have the new pulley to replace it. My question is how do i take the tension off the belt, i know this is probably simple but if someone could tell me what i need to do to loosen the belt i would appreciate it. Anything thing else you think I need to know or thaty might be helpful about this I would be happy to hear
Look to the right of your air conditioning compressor and you will see a tensioner. You need to stick a 1/2" drive ratchet or breaker bar in the square shaped hole and pull it towards the passenger side. That will allow you to take the belt off.
Car: 91 rs
That's what I thought I just wanted to make sure. I didn't want to break anything or have anything fly off when I went to loosen the tension. Thanks Again
evilstuie
01-09-2020 09:29 PM
evilstuie
04-14-2016 09:52 PM
sailtexas186548
08-24-2015 11:11 PM
Navy8125
08-22-2015 08:13 PM
Street Lethal
08-12-2015 12:33 PM
