cutting braided line questions
how hard is it to cut braided steel lines and put fittings on braided lines. ive never messed with braided lines before, im sure i can do it, just wondering whats involved.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Wrap electrical tape around the line where you want to cut it and cut it with a fine tooth hacksaw.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If the braid flares out a little and you can't get it into the fitting, put a screw-type hose clamp about 1/8" from the end of the hose and tighten it down until it squeezes the hose enough to get the fitting on.
84z96L31vortec
08-20-2017 12:16 AM
ambainb
04-25-2016 09:21 PM
