Bare Heads
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Bare Heads
If i get bare heads, do i have to get a valve job to machine the valves seats for the valves? Or are the valve seats already machined and ready for valves?
Theoretically, assuming a new head with installed guides and new valves, you shouldn't have to have a valve job unless the angle of the seats does not match the valve (there are other theories about slightly different angles being used but I don't think that is what you're worried about). The suppliers of both products should be able to answer that.
A practical way to check is to put a very thin coating of Prussian Blue paste on the valve. Use a light weight coil spring (available at a hardware store) under the valve and inside the port. Lightly press down the valve and slowly rotate it on the seat. Remove the valve and check to see that there is an even blue marking centered around the seat. If there is not--depending how badly off the mark is--you should have that seat retouched. If it isn't too bad, you could probably get away with lapping the valves in (the same spring comes in handy for that).
I normally lap in the valves even if the head and valves are new.
Hope that helps!
Hope that helps!
Originally posted by ME Leigh
So its a good idea to do work on them anyway.
I've tried a couple different suction-cup, valve-lapping tools and I have gone back to the light spring method I mentioned. Cheap and effective.
92camaroJoe
08-13-2015 06:07 AM
