It's been sitting...
Car: 86 Z28
Engine: 305TPI stock
Transmission: TH700R stock
My 86 Z28 has been sitting now for about 3 years without being started. Needless to say I've been away for awhile. I know the battery is dead but is there anything else I should worry about before I try and start it? It has a full tank of gas (three years old) and three year old oil and fluids.
I would advise to change the oil, after 3 years who knows what that oil turned into (no offense) hmmm..... other than that the only thing I can say is to change the belts and hoses, they should be changed every two years. check the coolant and see if it is still good, look for leaks, pretty much do a basic check on the car and start it up. hope it still works
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Pull your plugs and put a "little" motor oil in the cylinders, after sitting for that long I'm sure condensation had caused a wee bit of rust, the oil will just help ease the rings back into the cylinders, it'll smoke for a little bit, but well worth it.
articwhiteZ
04-29-2015 04:18 PM
f-crazy
27
12-04-2006 07:49 PM
