Silv-O-Lite H3437 pistons?
I was wondering if anybody has ever used these. I just ordered a set of these from Summit, but they're on backorder, so I still have time to cancel. They're 10.6:1 compression with a 58cc head (9.9:1 once I switch to a 64cc head) and they're hypereutectic. They seem to me to be a great deal, since this car's going to be primarilly a street motor. Definitely gotta be lightyears away from the stock pistons.
lot better than stock, lot stronger than forged, also a lot more brittle. they don't hold up well with power adders or detination. i've used them several times. read the install instructions and make sure you run the right end gap. if i recall you have to run stock end gap + 40%.
Car: 4
Engine: 6
Transmission: 5
The hypereutectic pistons are made of a material that's a good insulator, so the top of the piston gets alot hotter than other materials, so the top ring especially expands more with the heat... a small amount of blowby there is no big deal, but if the ring expands enough that the ends butt, you get more or less instant destruction of ring, piston, & cylinder wall.
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
Dragonsys
09-25-2015 03:51 PM
