Need help installing oil cooler.
Car: 1987 IROC-Z
I just bought a Transmission cooler for m car, I am going to use it to cool my motor oil.
How would I go about installing it? What I mean is what hoses would be the easiest to splice into?
I am also going to bypass my factory oil cooler.
How much cooler would my oil be with an after market oil cooler??
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Re: Need help installing oil cooler.
Car: '82 Z28
I would tend to think the transmission cooler wouldn't have big enough lines for use with motor oil. Previous owner of my old Nissan truck installed an oil cooler and it had some pretty big tubes and lines compaired to tranny coolers.
my oil cooler has 3/8 npt fittings and i ran -16 lines from the filter, and -16 to the filter, my oil filter is on the frame rail. i wouldn't trust the barb fittings on your trans cooler you have. you only have 2 options of lines to use and cut into and you need both, supply and return. the best route to take would be to use new lines if you don't entirely give up on it and get a real oil cooler.
ambainb
04-25-2016 09:21 PM
toronto formula
11-10-2015 06:17 AM
Navy8125
08-21-2015 09:32 AM
