Bad Vibrations 1000-2000 rpm help!
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
The whole car shakes between 1000-2000 rpm! Not at idle or above that exept at WOT in D, look below......
Doenst matter if in D, OD, P or neutral......
It feels like it worse in D than in OD when I drive. When I am at WOT in D it shakes all the time......
I recently replaced my tranny mount so I'll crawl under and check it...otherwise I dont have a clue?????
i'd suspect a miss or dropping a cylinder and not a drive train or suspension problem, they usually only get worse with speed or rpm increase. check the tune up and make sure there isnt a problem there, might want to do a compression test also.
someone972
08-30-2015 12:52 AM
