Schrader Valve - Fuel Rail
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
my schrader valve has begun to leak(88' TPI). where can i get a replacement valve core for the schrader valve on the fuel rail. i went to the dealer today and told me the part has been discontinued????? where can i get a fuel rail schrader valve? or what are they called under the auto parts computers? they couldn't find it??? thanks alot.
might have to replace the whole line, i doubt if part stores have them, or try junk yards. i had problem buying fuel line o rings for a ford, had to buy the line to get the o rings, at least that's what i was told. i think i may of had an inept parts man. i went to gm parts and bought the o rings a nd the ford never knew the differance. you might want to check ford or dodge parts, i'd damn near bet the valve is the same.
Car: 1990 GTA
Transmission: manual/t56
you might try your local autoparts store as well. I think that they might stock those vavle in the help section. If not I would try another dealer who may have one sittng on a shelf. If they don't have one ask if another year or car uses the same part.
Try a core from a refrigeration service valve. They are rated for oils and solvents, and for a lot higher pressure than your fuel system can produce.
Be prepared to spend a whole dollar to get one.
R3500
08-17-2015 12:16 PM
