Specs on L98 iron heads
Does anyone have the specs on stock L98 350 iron heads? I'd like to know the intake and exhaust port sizes, the combustion chamber size, and typical flow rates if possible.
Thanks!
Thanks!
Don't know the port sizes but the combustion chamber size is 64cc. Flow rates are as follows:
Intake:
@.400" - 178cfm
@.500" - 190cfm
Exhaust:
@.400" - 114cfm
@.500" - 115cfm
Hope that helps a bit.
Intake:
@.400" - 178cfm
@.500" - 190cfm
Exhaust:
@.400" - 114cfm
@.500" - 115cfm
Car: 1991 Camaro Z28
Just to expand on the flow numbers posted.
Lift Intake Exhaust
0.1 53.9 41.6
0.2 111.2 95.2
0.3 157.3 112.4
0.4 182 116.6
0.5 192 116.9
0.6 193.6 117.6
28" water
Here's where it's from...
https://www.thirdgen.org/techbb2/sho...ight=iron+head
David
Lift Intake Exhaust
0.1 53.9 41.6
0.2 111.2 95.2
0.3 157.3 112.4
0.4 182 116.6
0.5 192 116.9
0.6 193.6 117.6
28" water
David
Chuck84TA
07-15-2016 09:05 PM
ambainb
04-25-2016 09:21 PM
