set timing with tan/black wire hooked up did i mess some thing up?
I swapped out my 305 for a zz4 with the tpi. I never set the timing on a car before so i didn't know about that black and tan wire, but anyways i adjusted my timing to 10* btdc with the wire hooked up. Could i have messed up my spark curve or anything like that ? I finaly did it right and set it with the wire unhooked, but i was just wondering if i screwed anything up and if i did is there a way to reset it and do it over or something? oh ya it does run just seems to be severly lacking in the upper rpm's i know its from the tpi but it seems like it's a little too much. I ran a 14.24 at 95mph with a 2.14 60ft in like 110 degree heat with 2.73's and street tires. its killer off the line then just stops pulling.
