Engine shuts off under hard braking
OK,
I got a new PCV valve, and check valve. Then I took off the pcv valve and put on a breather and capped the vaccum that ran to the valve cover (now I REEEALLY smell oil/exhaust). I still need to get my vaccum tested with a gauge which will happen this weekend...and get my fuel bowls tuned by my mechanic. Besides that I may need a new diaphragm, I am thinking oil might have gotten into it and screwed it up. If I need a new diaphragm, should I just get one from the ol boneyard...there's a TBI camaro there that I get parts from. Or should I just get a new one? I have no idea how much that stuff will cost, or how big of a job it is. The only thing that makes me think that its not the diaphragm is the fact that I have only been having this problem since adding the new Street avenger carb. I want to get this fixed so I can race rice knowing I can stop if need be without the engine turning off.
--Dan
P.S. This is my friend'sl Screen name. I am 86IROC350NY. My friend has a riced corolla...he will never learn...Runs 15s with a 50 shot of nitrous.
Dan Ciccarelli
1986 camaro: 350 crate, edelbrock perf intake, Holley670 S/A, Summit headers, flowmaster exhhaust, no smog/cat, Accel 300+ Wires, Ported heads, Corvette cam, Dunlop sp8000 tires, american racing 16" rims (baja style).
Parts ordered yesterday:
Pete Jackson Timing gears (just for the noise
), MSD HEI kit with 6AL, Action Traction lift bars, GR-2 Shocks and struts, Edelbrock Strut tower brace, Comp engineering SFCs, 160 thermo, X-tream air filter (K&N), March underdrive pulleys (crank, alt, and water pump).
Next:
Performer RPM heads, and Crane energizer cam...once I get $1,300
--Dan
Dan Ciccarelli
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Next:
I am a "*****" yet I am the one that told him to get all those nice parts he has listed at the bottom of his sig...
PS: My "riced up corolla" is faster than you beat down Iroc....![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
BTW my car has never left me stranded...so yes I did learn....lol..
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1985 Trans Am
Axle/Gears: 3.70
Do you have the brake vaccum line running to the carb or to the manifold? When I originally had mine to the aftermarket carb I had the same problems. When I switched it to a manifold vaccum source that cured it.
