distributor mechanical vs. vacuum advance
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 SC
Engine: 5.0 305 LG4
Transmission: M5
does anyone know if there is a difference between a vaccuum advance and mechanical advance distributor? I was advised to change my original electric advance distributor over to a mechanical advance and a vaccuum advance. I was wondering which one I need in oreder to run an edelbrock carb, and also is there anything extra I need to do to hook it up or is it the same procedure????
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
1 Post
Car: 99 Formula
Axle/Gears: 342
If you're going with a NON CC carb, you need a vacuum advance distributor. The computer is now eliminated and you'll have to take care of the TC LU if you have an auto.
there is a big differance, one is mechanical and one is vacumn controled. if you eliminate the ecm controlled distributor and use a hei non ecm part it will have mechanical and vacumn advance both, my msd distributor doesn't have any vacumn.
nhra-trans-am
Southern California Area
09-17-2015 10:16 PM
86IROC112
08-17-2015 02:00 PM
advance, computer, difference, distr, distrib, distributor, distributors, electric, electrical, mechanical, my, s10, switch, tech, vacuum, vs, whats, why
