Converting 2 bolt main to 4 bolt
Is it possible to convert a 2 bolt main 350 SB to a 4 bolt main? Somebody told me the saddles where to thin on the 2 bolt 350 to add the second set of bolt holes in the block to mke it a 4 bolt, is that true?
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Re: Converting 2 bolt main to 4 bolt
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The castings are the same whether 2- or 4-bolt. So, the saddle is actually weaker on a factory 4-bolt block than on a 2-bolt. The splayed caps are the correct way to do a 4-bolt, which can only be done to a block that was delivered from the factory as a 2-bolt.
Black89TA
Exterior Parts for Sale
07-23-2016 10:42 AM
ambainb
04-25-2016 09:21 PM
