just wonderin
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
just wonderin
hey guys i was just wonderin wut would happen if u put the head from the right side of the engine onto the left side? would it just bolt up and be fine or wut?? thanks
It's spelled W-H-A-T not wut...unless you're a future French Fry Chef at McD's.
Assuming it's a smallblock Chevy V8 no problem swapping heads from side to side. Accessory holes, temp switch, etc. are identical.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Car: 89 Formula
Engine: Carbed 5.7
man thank *** cause i just fished my 350 build and i put the world 1.94 heads on and i wasn't sure if you could mix them up and i just put them on and everything lined up so i figured i was good to go. well thanks for answering my dumb question guys, and really W-H-A-T was i thinking lol
