Interesting Stroker alternative - Popular Hot Rod contest...
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Rules: Small block motor (any brand) under 366 CID (plus other rules, of course). Winning criteria: area under the curve.
One guy's approach: Stroke a 307 to 365. 3.935" bore, 3.75" stroke.
He thinks it'll produce more torque down low but as much peak as shorter stroke engines, and therefore produce more area under the curve.
More fuel for the "something different" fire...
Engine: LS1/LQ4
Not with a 283 block. The main journals are smaller, and by the time you turn down a 400 crank, you don't have any strength left. Offsets the oil holes, too. You could use a custom small journal 3.75" stroke, small journal crank, though ($$$$'s - ouch!).
The 307 used the larger journal mains, like 350s and '68-up 327's.
Originally posted by iroc22
Good point, forgot that it would be tough to squeeze the 400 crank in the small journal block.
xbmx89
South Central Region
10-31-2015 10:59 AM
